Which water temp switches will work for a 1985 115 Johnson
crb478
What year water temperature switches will fit on a 1985 115 Johnson. The OEM part is 0386686 but these are hard to find or expensive. Will any other years also fit? Which year heads will fit? It may be cheaper for me to buy a pair of good used heads than to buy the temperature switches. Thanks for any advise.
schematic
Re: Which water temp switches will work for a 1985 115 Johnson
1974 - 1987 will fit
They are expensive, but so is a cooked engine...
boobie
If you buy used heads you still don't know what you're getting. As said above, cooked mtrs aren't cheap.
