Which SS Prop? Lexor 15 or 17?
CorvetteTim
I have a 2004 Rinker 192 Captiva, 5.0L 220hp, alpha one with 1.62 gears. Right now I am running a 17p aluminum prop and the boat will hit 5,000 RPM and about 47mph or so.<br /><br />I am looking at the Lexor 15 1/2" 17p prop to put on. We do a lot of wakeboarding with this boat and when we have more than 3 people and try to pull a wakeboarder it takes forever to plane out. Should I go down the 15p prop to get a better holeshot or will the cupping and surface area of the Lexor make that much of a difference? <br /><br />I don't typically drive the boat over 35 anyway so top end isn't a huge concern.<br /><br />One other thing, I am in the Denver area so I have 5200' of altitude that robs a lot of my horsepower. <br /><br />From what I've read on here this Lexor looks to be a great prop but I am open to other suggestions.<br /><br />Thanks!<br />Tim
walleyehed
Re: Which SS Prop? Lexor 15 or 17?
Welcome!<br />The Lexor is a great load prop with good bite and I think if you replace your aluminum with this prop, you'll have to vent the lexor to get the low-end power you'll need, but that's not a problem...any decent prop shop can do it, just have them drill 1/8" pilot holes and let you fine tune it.<br />You're at 5000RPM now, so I wouldn't drop the pitch any. Stay with a 17 and have it vented.<br />Your rig may be a perfect candidate for smart-tabs as well.
CorvetteTim
Thanks! Would I be better off with a different prop? I would rather not screw around with getting holes drilled in it and going back and forth between the prop shop. Is the High Five a better (way more expensive) solution?
walleyehed
If you don't mind losing some top-end, some cash and a huge repair bill if ever damaged...yea, it's ok. Venting is a 10 minute job for the shop...it's just 1 way to increase hole-shot and keep your top-end.
imported_bjs
what ya callin a decent prop shop????????????????
walleyehed
One that knows where to drill and what size to start with....They must also have knowledge of which side of the leading edge the hole goes on...<br />Crestview Marine on Central, in Wichita knows...
