I bought a 21ft Rinker last year and the guy I bought it from gave me two props, an aluminum with 19" pitch and a SS with 21" pitch. He said he liked to run the 19" pitch because it gave him better performance for water sports but I found at WOT with the 19" pitch I was over reving with a light load. I tried the 21" pitch and at a light load condition I was just below the engine max rpm, so ok good. Two question:
-If I run the 21" pitch with full gas and say 6 people, I don't reach the max rpm at WOT, so this is overloading the engine right? As long as i stick to slower speeds (well below WOT, say 3000 rpm, the normal cruising speed), when I have this "heavy load" this will not over load the engine for the trip right, only if it tried for WOT?
-Also if i put on the 19" prop from water sports and then I want to go cruise somewhere, as long as I dont go WOT which over revs the engine, there is nothing wrong with this, right?
This is just a sanity check getting ready for the ever slowly approaching boating season......
