steam_mill
Thread starter- Joined
- Jan 16, 2002
- 413
A couple of weeks ago I purchased an old Merc 75. Early eighties. It runs well. Carb work, water pump etc.<br /><br />I had the dealer throw in an extra prop. <br /><br />The boat is a 12' aluminum. Figure no more than 150 lbs.(I'm guessing). <br /><br />The prop that came with the motor is a 9" pitch two blade. The second prop is an 8" pitch prop three blade.<br /><br />Both props are in great shape. The three blade is still painted. No knicks in either prop.<br /><br />I don't own a tiny tach and have no immediate plans to buy one.<br /><br />With the 9", the boat seems to go slightly quicker and not rev as high. With the 8", it revs higher and is slightly slower. Pushes the boat better with more on board (as expected).<br /><br />Any suggestions as to which prop I should use? I'm afraid of lugging with the 9" and over reving with the 8".<br /><br />I realize it is only one inch which should be no more than a couple of hundred RPMs.<br /><br />Comments? Which one would you use?<br /><br />Tx.<br /><br />Joe
