FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
You need to provide the performance numbers from your current prop. Rpm's at wide open throttle(WOT), top speed, current prop aluminum or stainless steel, what you do with the boat, high speed, water sports, etc.
dont know the speed, wot is 4200 book max is 4300, aluminum prop is on it now, mostly pulling tubes, skis and kneeboards, so i dont need alot of speed, the boat is hardly ever run wide open and running 70 mph is not wanted just need a good hole shot and speeds of around 15 to 20 will be just fine, however with that said the tubers i pull are pretty heavy and most run in the 200 lbs range, i dont have any propblem with it now unless i want to pull two tubes then it is a litle slow getting out of the hole, once done it planes and runs fine, i just didnt know if i needed to stay witha 17 pitch with four blades or not, thanks richard
