Which 20-24' pontoons have 24" center cross channels?
jsprat
I am searching for a used 20 to 24' pontoon but I do not want one that has 24" center cross channels. If I knew which brands had them I could eliminate that brand from my on-line search. This would save me from having to read the specs everytime.
Thanks for your help
rickdb1boat
Re: Which 20-24' pontoons have 24" center cross channels?
Bentley for one..
5150abf
Welcome to iboats.
Why so opposed to 24'', it has worked fine for many many years.
You are really limiting your market with just 16 since it is fairly new thing, probably in the last 3-4 years and as far as I am aware noone builds all thier boats 16 , they do both so you would have to look at each model from several builders.
I personnaly think it is a sales gimmick of sorts, while it does add some strength it also adds a bunch of weight and cost.
I am at Bennignton and we have boats that are 16 but we also build alot with 24, I have run both and would be really suprised if you could pick the boat that has 16 just by running it.
If they are done correctly with M brackets, 4 attachment points to the tube and good cross members, I really don't think the added weight is worth the small increase in rigidity you get.
You are almost going to have to go to the manufaturers web site and see what models have the 16 centers and then look for one of those boats used but as I said, it is a fairly new thing so you may have a long road ahead of you.
EGlideRider
+1 for 5150... Why buy something not needed??
flounderman
1985 Lowe 24' Sunbird. It has a 20' deck, the first 4' is 24" spacing and the rest are at 16". Lowe made a lesser priced model and it may be 24".
