wheres does this wire to?
Dborun
what would this be? its by carb and has a wire coming from the bottom. where does it connect to? i got a 64 evinrude 40hp
w2much
Not a good picture. Guess is a ground wire to shut off button or switch.. Cap it
Dborun
its this small looking type cylinder has a wire coming from bottom of it and is not connected right now.
F_R
Honorary Supreme Mariner
Choke solenoid. I have a feeling you will be back with another question. There was a change in the 1964 choke wiring.
Dborun
ha ha so does it need to be hooked up and to where?
F_R
If it actually is the solenoid wire, it should be obvious where it came from. If not, maybe it isn't what we think it is. Anyhoo, with the original setup, the choke was activated every time you turned the key to start. But if you did not want it to choke, there was a choke override switch. The system totally blew everybody's mind, so the override switch was replaced with a choke switch so it only choked if you wanted it to instead of whenever the key was turned.
