If it actually is the solenoid wire, it should be obvious where it came from. If not, maybe it isn't what we think it is. Anyhoo, with the original setup, the choke was activated every time you turned the key to start. But if you did not want it to choke, there was a choke override switch. The system totally blew everybody's mind, so the override switch was replaced with a choke switch so it only choked if you wanted it to instead of whenever the key was turned.
