where to throttle on cold start
chuck1443
i just got a ranger370v gt150 johnson 85' do i need to throttle up when cold starting if so how far the shifter isnt marked
Joe Reeves
Re: where to throttle on cold start
Yes, on a cold start, you'll need to apply a slight bit of throttle. However, you don't want to have the rpms increased to an extremely high point. Remove the hood and watch the throttle butterfly lever(s)..... move the warm up lever untill they move about 1/16" to 1/8" (somewhere in that area). Now, when the engine starts, take notice where you have that warm up lever and move it to a position where the rpms feel right and make a mental note of it. Just takes a little practice.
stylesabu
Master Chief Petty Officer
or how about just enough to keep it running,or a little higher, 100 rpm or so.then if you need to make a referance mark.
stylesabu
sorry meant, kick it up 100 rpm or so over idle speed needed to keep it running. then, make a mark, so you know where to set it.
