Re: where to install tell tale 1959 35hp johnson
A pretty healthy spray at that. No need for a tell-tale on these old motors.
In 1959, nobody had a tell-tale except Mercury and Elgin. Well, OK don't jump me, I can think of a couple more. The point is, in 2009, everybody figures they have to have one.
The best insurance against cooling failure is to know darn well that you have a good water pump in there. Then you don't have to worry about it.
Or, you can rig up a tell tale and spend your boating day with your head screwed around backward to watch the squirt. Chances are slim to zero that you will be looking at it when the pump self-destructs anyway. When that happens, you have about 5 seconds to shut it down. So be sure to check it every 5 seconds or less.
