where to get used motor?
petrey10
where can I find a good used motor? I know its hard to find but ebay is the only place I know of
DukesFin
Re: where to get used motor?
I don't care where you buy a used motor, you are still gambling on it being a "good" one.
Professional boat mechanics can't tell you if a used motor is good... I'm assuming your definition of good means it is in fine working order...
It might start today and be dead tomorrow. Even a new motor can do that, but at least you would have a warranty!
sea wolf
The only way to tell if it's "good" or not is to run it. Unless you plan on doing the labor yourself, if u get a bad one you're out of luck. There are companies that offer remans, but I have no experience with them. What are u looking for?
petrey10
mercruiser 140 3.0L.....the block on mine is cracked and junk along iwth the exhaust manifolds.... How about finding a block? I found one on ebay but its bored .030 and the cost of pistons would be expensive wouldn't it?
petrey10
i know its fairly common engine and I should be able to find something shouldn't I?
bomar76
The 3 liters normally outlive the boats in which they are installed.
It takes a lot of neglect to kill one, so they are pretty plentiful on the used maket as the boat usually dies before the engine.
petrey10
thats the problem the previous owner didnt drain the engine and it froze during the winter
woodrat
Ensign
craigslist can be a good source.
You could just look for a core and have it rebuilt.
petrey10
East Central Illinois....if anyone knows where I can get either a block or complete engine Mercruiser 140 please let me know............also another question would be do all the years of 140' fit to the same outboard unit?? MY boat is a 1971 Larson and the serial number comes from liek 1967 (engine #). Would a new engine still fit on the same outboard part of my 1971 Larson?
petrey10
i am thinking about just junking the stupid thing
