Fisherball
- Mar 19, 2009
- 470
Maybe a dumb question but why put glass on a flat, supported surface of plywood that's sealed with resin? Just curious because I know structurally the plywood will deal with the weight on it. I'm planning on building a live well from plywood, sealed with resin & glassed over inside, especially corners, where I will fill with a wood flour/resin mix. Should I glass over top & outside of sides? It will sit on a casting deck I am adding over the front seats of my tri-hull bowrider but the top will probably be stood on occasionally. Should I also glass the casting deck?
