where is the oil plug for a johnson 140 outboard
relentless
where is the oil plug located on a Johnson 140 outboard? I have looked in the manual but can not find it. Help
ezeke
Re: where is the oil plug for a johnson 140 outboard
If you are speaking of the gear oil, there are two plugs, one for venting one for filling.
They are slotted screws near the top and bottom of the gearcase.
The engine oil is mixed with the gasoline unless you have a mixing system in which case the oil is in a separate tank in the boat.
Vic.S
Or are you talking about a 4 stroke ?
Year and model number would enable us to identify the engine.
kenmyfam
Post the model number and year (if known)
