Where is it suppose to go? Pictures would be a big help. 1993 200hp Evinrude Ocean Pro.
P pafisher1234 Seaman Apprentice Thread starter Joined Oct 4, 2008 Messages 46 Mar 22, 2010 #1 Where is it suppose to go? Pictures would be a big help. 1993 200hp Evinrude Ocean Pro.
D DJ Guest Mar 22, 2010 #2 Re: Where is the hose that goes on this fitting go? Looks like the telltale port. It shoots water out of the block to vent it and let you know the water pump is working. It should go to an opening in the bottom cowl.
tashasdaddy Honorary Moderator Emeritus Joined Nov 11, 2005 Messages 51,019 Mar 23, 2010 #3 Re: Where is the hose that goes on this fitting go? i vote recirculation hose. tale tell is at top of block.
E ezeke Supreme Mariner Joined Sep 19, 2003 Messages 12,532 Mar 23, 2010 #4 Re: Where is the hose that goes on this fitting go? That is the tell-tale (overboard indicator) outlet in the adapter plate. If your tell-tale is routed elsewhere, you should plug that one.
P pafisher1234 Seaman Apprentice Thread starter Joined Oct 4, 2008 Messages 46 Mar 24, 2010 #5 Re: Where is the hose that goes on this fitting go? I have nothing else missing a hose like that. Can I put a bolt in it?
E ezeke Supreme Mariner Joined Sep 19, 2003 Messages 12,532 Mar 24, 2010 #6 Re: Where is the hose that goes on this fitting go? No, it's 1/8 NPT; get a plug from the plumbing department at your local hardware store. You can also use that elbow for the connection for a water pressure gauge if you want.
P pafisher1234 Seaman Apprentice Thread starter Joined Oct 4, 2008 Messages 46 Mar 24, 2010 #7 Re: Where is the hose that goes on this fitting go? Ok thankyou.
