Where is Depth Finder transducer located
ssmith23
I have a 2003 Bryant 200 series bow rider. Transducer on the Teleflex (now owned by Hummingbird) depth gauge seems to have failed. Dashboard display works and I can set shallow and deep alarms but do not get any actual depth readings. No indication that the transducer is external and not visible in engine bay.
Any suggestions?
mike_i
Is it on the transom? Have you looked under your boat if it's a thru hull? Have you traced the cable?
