where is coupler located?
potatoe
on a mercruiser 4cylinder i/o, what and where is coupler? thanks
Doernuth
Re: where is coupler located?
The coupler is bolted to the engine flywheel and is where the shaft from the outdrive is inserted. You must pull the drive and the engine to get to it, but you may be able to inspect it by just removing the drive.
