where does the water pump hose connect?
marvin the minnow
I know the hose follows the shift shaft up when re-installing the lower unit but I do not see anywhere to connect the push fitting.
marvin the minnow
Re: where does the water pump hose connect?
the other end is actually capped so I suppose its not a water hose. not sure what its for but ill just slide it back through up next to the shift shaft.
