Where do i start?
DebH
Just inherited a 1997 Crownline 182 w/Volvo Penta 4.3 GL I/O motor. The trim & depth finder gauges won't work.
Is it a fuse? I looked under the dash but, can't really make out what wire is what, nor does it look like I can get to anything way up in there....
Silvertip
Honorary Supreme Mariner
Re: Where do i start?
Gauges are not fused. They are fed by the engine electrical system. The gauges need +12 volts and ground. The trim gauge "S" (sender) terminal is fed from the sender on the engine. The depth finder has a transducer. Make sure its clean and connected.
burp
The depth finder will most likly be manufactured by Hummingbird as Crownline switched over the Lowrance depth finders around the 2000 model year. The trim gauge will be manufactured by Faria. The Faria website has some troubleshooting hints for their various gauges, under "Misc. Instructions". http://www.faria-instruments.com
