where do i go
captbjack
hey guys where would i look for typical boat setup, i am having problem souds like my motor is cavitating when i trim it up to far.
HighTrim
Re: where do i go
Take a pic of the stern of your boat, eyelevel with it. The guys on here will be able to guide you after that.
captbjack
Re: where do i go
will try to get that in the next few days allready past bedtime now and have a tourney tommorow, thought there would be a standard setup. laying a straight edge on bottom of boat it goes just above the water inlets on foot.
tashasdaddy
Re: where do i go
when you trim too far it is going to blow out. laying a straight edge on keel of boat the AV plate ( plate above the prop) should be 1 - 1 1/2 inch above the keel. proper trim is considered, getting the boat as fast as it will go, without blowing out.
F_R
Honorary Supreme Mariner
Re: where do i go
Sure it's normal. It is the result of trying to get the last ounce of speed out of a rig. You have the motor jacked way up for speed and there is a limit.
captbjack
Re: where do i go
guilty as carged:D
