Where do I fill the freshwater tank ?
Polar_Bus
Hi all,
can someone help me, I can't locate the fill point for my freshwater holding tank. Where is it? I have a '98 220CS. Thanks!
Rich
rainman240cs
Re: Where do I fill the freshwater tank ?
try the stingray website, plenty of good info there.
newwater
Steve I have a 1995 729zp same as a 240cs and the filler for the fresh water is beside my right leg at the helm. good luck this summer
jay_2179
:confused:Did anyone figure out where it is? I looked on the Stingray website and no luck. It is not near my helm either.
learning curve
Guys,
The fresh water tank for the Stingrays is located under the front panel in the cuddy. If you lift the cushions, and remove the front panel, Reach inside the panel and you will find a removable bladder type of container. It only holds about 3 gallons of fresh water.
Also, Polar Bus, I am docked on the Merrimac River so if you have any other question let me know. I am all over the north shore from Essex,MA to Portsmouth, NH.
Keep it safe ! Gary
Polar_Bus
I STILL can't find this "bladder". Exactly which "panel" are you reffering to? The only removable panel I can see under my cushions is my storage well for my lifejackets?
jacquestrap
Hi all,
Rich
it is a collapsible 1 or 2 gallon container that attaches to a hose and is stored under the front cushion bin, i had the same problem finding mine. You might have to buy the container and hose.you undo the faucet screw and pull the faucet out, the hose attaches to the nipple on the underside and then you fish it throughto the front storage bin,very low tech...
