where do i connect the battery cable
predator165
can anyone tell me where the connections are for the battery cable on a suzuki df70.
kind regards
ron
JB
Re: where do i connect the battery cable
The positive cable connects to the starter solenoid and the negative (ground) cable is bolted to the engine block.
It would help if you gave us a bit more info. Those cables are normally part of the engine wiring harness.
