where can I find flotation foam in Canada (Ontario)
deputy00791
I am looking for flotation foam for a restoration project 18' bowrider. Can't seem to find any supplier here in Canada.<br /><br />Thanks you
tr918
Re: where can I find flotation foam in Canada (Ontario)
Try online. UsComposites (shopmaninc.com) has decent prices. I don't know the cost to ship to Canada though.
AMD Rules
Check out<br />Dwyer Hill R.V. Resort<br />1229 Dwyer Hill Road , Ottawa ON, K0A 1B0<br />(613)257-2568<br />They -may- offer what you need.
dolluper
Or Noah's in Toronto ,they have everything.<br />noahsmarine.com<br />54 six points road<br />They have a downloadable cataloge but the prices are higher it's a 2002 cataloge
Evinrude Boater
Dolluper is right. Noah's has all your boat building supplies. 2lb foam is $89 for a 8 liter kit, that's basically 2 one gallon pails. Their web site is noahsmarine.com. They'll even ship it to your door for cheaper than the gas to drive there.
TELMANMN
If you can use flat insulation then use extruded sytrene(pink). It is impervious to water(used inground against a foundation). Can be cut and shaped so should work. Find at any home store.
Evinrude Boater
Telmanmn, I wouldn't say extruded foam is impervious to water. It's quite resistant but will soak up water like a sponge if kept under water. When used on foundations the water is meant to drain away to the weeping tile so the insulation is not under pressure from the water. When used on inverted or upside down roofs (flat roofs with the insulation on top of the roofing membrane) this insulation often would stick to asphalt membranes and also be held down with the gravel ballast. If water accumulated on the roof, the insulation would eventually soak up water and be so heavy it would break when you try to carry a piece.<br />In my opinion, you're just making a bad situation worse using layers of board stock all cut to fit. There's no support, there's lots of gaps for water to accumulate and go moldy, they will move around and wear and move around more. I pulled board insulation out of my boat and it was all broken and this way and that way. What a mess! But hey, that's just one man's experience.<br />Classic
