Where can I buy outdrive boot
avery52507
I just purchased a 1985 Renken with a 3.0 i/o where can I buy the boot for the outdrive its torn, and will I need any other seals etc when I take the outdrive off. Any help would be Greatly appreciated, the Big Rockfish are here and I want to get out there Thanks in Advance
thrasher
Re: Where can I buy outdrive boot
You might want to tell us what outdrive you have (Mercruiser, OMC, Volvo, etc)? What do you mean by boot? Are you refering to the bellows that go around the drive shaft or something else?
79Glastron
I assume this is an OMC stinger drive?? I would check this site for parts first.
Haut Medoc
Welcome to iboats......:)
Post up what drive you have for a better response......;)​
avery52507
sorry guys yes it is an OMC its the "black boot" transom seal that goes around the outdrive to keep water from entering the boat. I've seen the topic on here about the "boot" tearing or dry rotting. what is the proper name for this part and where do I get it I cant find it on here but I also dont know the proper name for it to do a search. I'm also not sure what type of outdrive it is, what was common for that year (1985 renken)? Thanks for the fast response to my last question sorry it wasnt more complete.
