Whats wrong with this old outboard?
Dbill27
So I've got a 1974 johnson seahorse 25hp. Got it cheap from someone, they let it sit out all winter at least. It was originally starting pretty easily but would shut off after about a minute and wouldn't idle. I changed the impeller from a kit i got on iboats. The impeller seemed to large for the housing so I had to bend the impeller blades all in the same direction to fit it in, Is that normal first off? Either way since then it will occasionally start on the first try after sitting for a while run maybe twenty seconds at most and cough and shut off and will not start on the second attempt. If it sits a couple days then it may start again and do the same thing, or it may just not start at all when I pull. Does anyone have any idea whats wrong. I took the carb off and sprayed everything out but it actually looked pretty clean, all the fuel lines seem tight and without leaks. The primer bulb seems fine and the last time i was able to get it started i started squeezing the bulb to see if that would keep it running but it did not and died quickly.
I have not taken out the spark plugs or have done a compression test. Any comments are appreciated
Vic.S
Compression test is a sensible first step ... but since it starts Ok probably OK
Check clean reset or replace plugs They should be champion J4C gapped at 0.030"
Check sparks They should jump 1/4" gap with a nice hot blue spark
It's points ignition so if no joy with the sparks clean reset points to 0.020". They should be cleaner than a clean thing.
Also inspect condition of coils.
Since it starts I expect all the above are probably OK, also condensers
If still no go with good compression and good sparks you may have to do a full carb clean.
Wondering if its flooding. Try disconnecting the fuel line after priming with the bulb... see if it runs any longer. Also if it can be restarted more easily.
If so maybe float and or needle valve need looking at
( what you say about the fit of the impeller is normal)
Lots of useful advice on the FAQs board http://forums.iboats.com/forum/engine-repair-and-maintenance/engine-frequently-asked-questions-faq
steelespike
First off get that compression checked. Check the gear case (don't remove the small philips screw).
Once you know the condition;
check the coils under the flywheel.Points need to be clean and set at .020.
Go through the fuel system from tank to carb.
If your testing in a barrel be sure the water is up to the mounting bracket.
I would guess your problem is in the fuel system.
If you got it cheap somewhere they probably didn't do you a favor.
henleyhale
I had a buddy who had this issue once on a like motor ended up being a oversized fuel pump the p.o had installed when the original went out. If it's new to you see if that vacuum pump looks a little BIG. It was starting up and running after fuel had dissipated and then would flood the carbs all over. If your plugs condensers wire s all look good check your compression and overhaul the carbs
