what's this fitting '93 40hp Johnny
tashasdaddy
TJ40ELETB just got this motor. no manual yet. bad me. the fitting is circled in red. the tale tell is purple, and connected to the proper place according to the BRP diagram, down at the bottom. it looks like a second tale tell. but no where to go.
rudedude
Re: what's this fitting '93 40hp Johnny
I am looking in my manual and haven't see that gizzmo yet. Can you back the picture off a little? I need to see the whole side its on.
tashasdaddy
it looks to be original, but the tale tell is connect down low, and is the hose coming over the head.
rudedude
Iam looking for it . There isnt another like fitting down near the bottom? anywhere?
rickdb1boat
Looks like someone used that spot for a water pressure gauge hookup...
rudedude
I have seen these before and what I remember is there is a tube that runs to another fitting like the one pictured, I belive it to equlize the pressure. Looking at your pictures it seems the motor has been run with out anything connected . If you have a oil build up around the fitting or where its aimed at then its what I think. If you can turn the motor over see what if anything comes out of the fitting . I cant see the blasted thing in my book but will keep looking.
tashasdaddy
it's in the water passage cover, no evidence of anything. i guess i'll have to get it mounted and see what comes out. i like the sounds of the water pressure guage. if so i will just block it, for now.
rudedude
That is what is called for, a plug.
harlan_ss
I have a 93 50hp.
Plug is up on top.
Water pump fitting down at bottom connected to hose/indicator.
Service manual for my 93 shows plug up top.
tashasdaddy
i got it mounted and started yesterday. yes, it was a water line. probably for the water pressure. just capped it off.
