Whats the trick
H2Odog
Whats the trick to removing the pivot rod, that the rod and eye from the tilt unit connect to?? I have tried a slide hammer and also put a 7/16" bolt on the other side and tried to beat it out :confused: Any tricks of the trade you care to share<br /><br />Oh 96 johnson 50HP
Joe Reeves
Re: Whats the trick
Use a hand held propane torch with a blow torch tip to heat the aluminum that surrounds the pin.
Walker
Re: Whats the trick
I've sometimes pulled the the motor off the boat and split the 2 transom mount brackets to get the pivot pin out. They can be tough.
rodbolt
Re: Whats the trick
I use a BFH and oxyacetylene.<br /> they can be a bear :) :)
H2Odog
Re: Whats the trick
Originally posted by rodbolt:<br /> I use a BFH and oxyacetylene.<br /> they can be a bear :) :)
Thanks guys. The heat definately helped. Still needed the BFH and a couple of beers :p It still was a pain in the a$$ :eek:
