whats the secret
ryr28fan
just wondering what the secret was to get a reply to a prob have posted twice and cant get any help
SlowlySinking
Master Chief Petty Officer
Re: whats the secret
Hi ryr28fan, sounds like nobody knows for sure. At full throttle the foward thrust of the engine should keep the engine real tight to the boat, the leaking cylinder may be your problem, maybe repair that and see what happens. Since the Tilt & Trim pump isn't in operation during normal boat operation the only thing I could guess at is this, are your T&T relays near the motor, there's a possibility one relay is vibration activating at full throttle and turning your T&T pump on intermittently. Easy way to check, remove the relays and go boating, see if the problem goes away. Good luck,,,
ryr28fan
Thanks for the replies. I did do a search and couldnt find anything that was having the bouncing prob It is definetly baffling me .
