What's on your boat wish list?
NHGuy
What have you done to improve your boat? What will you do eventually. And what is your no holds barred "I can afford anything" list?
I have done the maintenance stuff including bellows, shift cable, plugs yearly, cap, wires, rotor, fuel filter each year. Replaced a balky fuel level sender, did the fuel lines. After those maintenance items were up to date I happily needed a taller prop, so I got an aluminum one since I wasn't sure I had picked the right pitch.
Wet sanded & polished up the exterior. Installed a new marine stereo to replace a dead one. My kids plug in their Ipods and make me listen to music I don't like. But sometimes I can choose, I am captain you know! Replaced upper input yoke & seal on my drive. While the drive was off I sanded it and took out the marks on the skeg. Repainted the drive. A local auto mechanic I know just happened to have a new distributor sensor sitting in his toolbox unclaimed for ten years. He gave it to me, awesome. I bought him a 30 pack, he deserved it.
I have an extending flip down boarding ladder on order. The OE single step is getting too tough for our aging bones. Also, we have the excuse of my wife had shoulder surgery and can't climb the single step. Boy, time marches on, I at one point could pull myself into my dad's Glastron, without a ladder, after waterskiing til my legs ached.
I HAVE to do my interior over, should have done it this past winter.
So I'd like a stainless prop, trim tabs, maybe a power amp for the sound system. Someday I'm going to that marine salvage yard down the road and get a trim indicator gauge to match the ones I have.
And I am thinking I'd like trailer brakes cause my trailer and boat just barely meet the 3000 lb no brake rule. I put high performance rotors onto my truck cause normal rotors would heat warp a little even when I tried to baby the brakes.
Pie in the sky stuff... I'd like to try an Alpha SS lower unit, I would also like to see what a Land & Sea Sternjack would do. The Sternjack pushes the drive back a few inches into less turbulent water, the SS is shorter. Each is supposed to improve speed. I'd like to put modern heads on my motor and a roller lifter & cam setup for more rpms and power.
I suppose if I spent that kind of money I might be able to find a better boat though...Maybe I could rescue a tired Donzi Classic or Hornet.
Our docks only allow 21' boats, so the Hornet is the biggest old school Donzi that would fit. I envy Donzi 22 Classics and Century Coronados.
I know it's crazy, but it's fun to imagine the possibilities.
Restless22
Re: What's on your boat wish list?
I too want a longer ladder, I will buy it eventually along with a VHF radio and a better depth sounder and GPS. I don't want to put too much into it, as I am already thinking of what I want in the next boat.
Since I have pledged to be sober, I guess fishing could cure my off time boredom when tubing isn't an option.
I'm sort of at a crossroads. From the way that we have used our boat to date, a cabin just hasn't been needed.
Plus, my boat is *** heavy, and moving the 2 kids and wife to the bow to help get on plane I getting old. I'm learning a lot about weight and performance.
I am eyeing fish and skis and runabouts with an envious eye lately.
dingbat
I've been busy
New power head, Spring 2011
.............Renegade Offshore, 4 blade SS prop
Replaced all 10 plastic thru hull fittings with Stainless steel
Replaced every hose on the boat (fuel, live well and cockpit drains)
Replaced damaged pin striping on hull
Replaced main power distribution panel (glass fuse to maxi)
Replaced float type senders in both fuel tanks with “resistive” sensors
Replaced/ upgraded raw water washdown system
Installed Six tube, roof mount rocket launcher
Installed Blues Seas, 120A ACR system
Installed Bennett trim tabs w/ auto retract
Installed 8” Furuno sounder
..................Airmar 1kW thru hull transducer
Installed 4208 Garmin Multi-function display
.................Garmin GPS 17x HVS antenna
.................Garmin AIS 300 system
.................Garmin GFS 10 Fuel flow monitoring system
Installed ICOM 504A VHF radio
.................Shakespeare Galaxy 5225-XP VHF antenna – Stainless steel ratchet mount
Installed JBL MR30 AM/FM/CD player
..................Shakespeare Galaxy 5235-XT AM /FM antenna – Stainless steel ratchet mount
Future:
Armstrong ”offshore” bracket for motor
Garmin HD Radar, if I can figure out how to make the dome removal. Has to fit in the barn door
spdracr39
All I have left is to find an in dash depth finder that actually works and make my vapor lock issue go away. Since I bought it in may I have added:
smart tabs
6' bimini top in addition to the tower bimini
named and lettered
added second battery
swapped speedometer to start reading at 10 mph instead of 20
New Apollo XHS 17p vented prop
I will be adding when parts arrive:
Tower racks for skis and kneeboard
Trailer guide bunks
cooling system check valve to prevent hot water from flowing back to the cool fuel box
tincanman
My wish list is extreme. I would like to try out my boat in the water. Sitting in the boat in the back yard is fun, but....
Davem3
5 more feet would work wonders on me ..................
25thmustang
I want to finish the head, walls, trim and that will be set.
I want to recarpet her. Should happen this year.
I want to refinish the remaining cabin wood. This involves getting mahogany or teak for the cabinet door centers. This will take time.
I want to reupholster the dinette. I have the fabric, but not the time yet.
I'd love to get new motors... :D
dingbat
Boat wish list: Two foot more more. (It never goes away.) :D
For me, it went away the day the Visa bill arrived after I filled the tanks ($547) in the boat for the first time. Two days later it took $465 to top them off
Restless22
for me, it went away the day the visa bill arrived after i filled the tanks ($547) in the boat for the first time. Two days later it took $465 to top them off
yikes!
chris.j.marshall
Everything on my wish list would be a lot more feasible if I could just get my garage to magically grow larger.
NHGuy
Yup, the 2 feet would be great, but the fuel for the two feet. Now that's another question.
s freud
This. First however, I need to drill out some steel screws, replace some rivets, and repair all the holes in the transom. Then I need a couple paddles and to hack down a few bushes and a fence post to get my trailer into my yard instead of at the office. So, I should be ready to push off in an hour or two.
Ponderosa
I want to apply new bottom paint, finish the interior and paint my trailer. A depth finder, ship to shore radio,SiriusXm radio. Oh I almost forgot, a bigger boat.
acarter92
I brand new Catalina 32. I can afford the gas and my current boat can double as the dingy :)
Austin
jdlough
Master Chief Petty Officer
Well, I'm a bit embarrassed to say that I keep most of the fish I catch alive in the livewell, that's supposed to be used for the bait to catch them!
Apparently the builders of my boat expected me to catch walruses. The fish box needs about five 20lbs of ice even before a fish goes in there. I never did that. I figure that if I dumped 100lbs of ice down in that fish box, I'd be sure to catch nothing.
One fish box is too small, the other is too big. So, I'd like an expandable fish box.
tswiczko
That big one is a beer cooler not a fish box:D
Flysfloatsor
Banned
I bought the Bravo this weekend that I am replacing the Alpha with.
My wish is that the replacement goes smoothly and there is not many unexpected costs.
Some are ok (hoses, little things), but 2x the estimate when the drive is off and the motor is out seems like they know they have me over a barrel.
