fishngal23
Thread starter- Joined
- Aug 10, 2005
- 40
A friend of mine just got a Johnson super seahorse 33hp modle rx13b<br />serial j2509343.<br />I would like to know what year and what the gas and oil mixture is. <br />Also we put it in what and started right up no pee. Drop lower unit impeller looks good the small key that holds the impeller in place is good. Shaft is turing impeller. I hooked water hose up to water tube and turned it on. water is making its way through the motor and out the pee hole. Put lowe unit back on. No pee. thanks for all the help.
