Re: What year LU will swap on OceanRunner 225?
A V6 unit from 79 and newer will work. If your unit has an O ring on the driveshaft and you use a newer unit there will be no O ring. In that case just make sure you grease the splines.
If your driveshaft has no O ring (it'll be on the bottom of the crank) and you use an older unit with an O ring it'll just get pushed out of the way when you install the unit (if you leave it on).
The main difference between a crossflow V6 unit and a looper V6 unit is the shift shaft. Yours will unscrew so you can easily install it in another unit if you have to.
Any V8 unit will work, it just has a taller gear ratio and is bigger.
A V4 unit from 79 on will work but has a lower (2:1) ratio and uses a smaller diameter prop. The case is smaller too.
