What year is this motor
Gateswm44
I have a mercury 40hp 4 cylinder 2 stroke. I’m assuming it’s an early 90’s model but the serial number is not present. I’m trying to find a new tilt/trim unit for it.
GA_Boater
Welcome aboard, Gates.
Year of the Merc isn't important since the motor doesn't appear to be a TnT motor and you have a CMC aftermarket tilt and trim unit.
What's the problem with the tilt and trim?
flyingscott
Look on the block for the serial #. GA is correct that is an aftermarket unit.
Gateswm44
That CMC is more or less a transom extension. It doesn’t have trim on the bracket. The motor still has the stock trim unit. The trim was leaking fluid when I bought this rig so I replaced the seals in piston assembly. Doesn’t appear to be leaking anymore and works perfectly until I run faster than an idle. Once I’ve gotten up on plane and start to trim it out it only comes up so high before falling down. If I hold the up button it just comes up then down over and over like it isn’t strong enough to raise the motor under a load
Gateswm44
You can see how it’s set up a little better in these pics
jimmbo
You really need to get the Factory Manual for that engine, and that will require the Serial Number. Have you looked on the Cylinder area of the Block for what looks like a Welsh Plug, with Numbers on it?
Gateswm44
These are the only numbers I can find.
