What year is my 55 Hp 3cyl Johnson?
sballou
I have looked all over the engine and cannot find the model number tag. It is not where it should be and may have fallen off or been removed. The only number i have is what i believe to be the SN, which is J3005031. This is located on a silver "button" on the powerhead. I was originally told it was a 1973 but later found out 55 hp 3 cyl's were not made in '73. Can anyone tell me the year and model # of my outboard with this information? Thanks.
Hooty
Re: What year is my 55 Hp 3cyl Johnson?
We're gonna need the model nr. Look on the port side of the transom clamp, outside of the boat.<br /><br />c/6<br /><br />Hooty
wikelam
Model # please for further info. i think that the 55s started around 75-76 but these are two cylinder. might be older, bout 68
D
DJ
Guest
If it's electric shift, it's about a '69'.
sballou
There is no tag on the transom clamp and the motor does have electric shift. Is there any way to find out what the model number is with only the SN?<br />Thanks.
rickdb1boat
Ol' Ballou <br /><br />You would be looking for numbers such as these to find the year. These are normally on that welsh plug(Silver) that you found. Check around everywhere for numbers like these. Thought it might help if you knew what you were after.<br /><br />55R76-55RL76 55 1976<br />55ES69-55ESL69 55 1969<br />55E76-55EL76 55 1976<br />55E77-55EL77 55 1977<br />55ETL77 55 1977
seahorse5
They only made the 3 banger 55 for two years, '69 and '68. The '69 uses a round main wiring harness connector and the '68 used a rectangular plastic connector.
