What year is my 3hp Evinrude Lightwin?
TLAWS
We just bought an old 3hp Evinrude Lightwin outboard motor. We think we need to rebuild our carborator. So we need to know what year it is to order parts. The only numbers I can find is the serial # 3022-11052. We did have it running, but it's getting to much gas.
Bear
Re: What year is my 3hp Evinrude Lightwin?
3022 is a 1957 Evinrude 3 HP @ 4000 RPM 5.28 cu.in. = 86.5 ccm 2 33 lbs. = 15 Kg prop 6 1/8 x 6 1/4 , 2 blade gear ratio 17:28<br /> <br />Carb instructions (click and scroll down):<br /> http://www.maxrules.com/fixtuneitup2.html <br />Exploded view of the carb: <br /> http://www.maxrules.com/62threehp/3carb.JPG <br />A picture from the 1957 Evinrude catalog:<br /> http://mitglied.lycos.de/old_omc/e_1957/seite_26_27.jpg <br /><br />Good luck!<br /><br />/Bear
TLAWS
Thanks for the info bear, it helps alot! Could you tell us how to check to make sure it's pumping water, and how to clean and set the jets? :confused:
