What year is my 20hp merc
denis2
Hi I am new lad on the block Hope i am posting in correct place ----- I have bought a 20hp Mercury L/S manual it has a number plate on the swivel brkt. as follows OC291534 any one no what year it was built. I have checked a few lists on rhe internet but this number does not come up Thanks Denis
denis2
Re: What year is my 20hp merc
The s/n comes up as a model:
1200413LD MERCURY 1991 200XRI (175 XRI /175 MAGNUM 200 XRI (EFI)
Can you double check the number and also look on the powerhead to see if you can find a s/n disc like this:
http://img84.imageshack.us/img84/8224/391496208.jpg
Gerry
Thanks Gerry where exactly am to find this nunber plate. sorry I am not that familier with out boards-- Denis
carholme
Denis;
Look at the top of the power head for a metalized tag embossed with the Mercury logo, the date of manufacture, the model number and the serial number. If the tag is not in evidence on top of the power head, look on the lower-starboard side of the power head.
Also, re-examine the OC291534 and be sure that the C is not actually a G
Gerry
denis2
Denis;
Gerry
Gerry I found the round number plate the number reads C or could be a G not qiute sure followed by 231534 any help Denis
carholme
Denis;
OC291534: Model 1200413LD MERCURY 1991 200XRI
OG291534: Model 1040411SD MERCURY 1996 40
So, if it is a Mercury, we have a 200hp engine or a 40hp.
How many cylinders is it?
Gerry
denis2
Gerry It defiinitely a C231534 And looking at the colour transfer on the engine cover . On UTUBE there was a 20hp the same and was titled Mercury 20 hp year 1993 Thanks again Gerry
denis2
Thanks again Gerry for all you work So its 1991 model It has 2 cylinders that ties up with the boat and trailer year Tnanks Denis
denis2
Hi gerry I have a small question On my 20 hp Merc How do i remove the fuel sight fillter does it pull or screw off . Any Idea where I can get the owners manual for my 20 hp Mercury Thanks Denis
carholme
Denis;
Please bear in mind that I am not sure what year your engine is, though the parts listings favour the 1993. However for the 91/93 the parts listing is the same and here is the link:
http://www.crowleymarine.com/mercury-outboard/367.cfm
See your fuel filter under FUEL FILTER ASSEMBLY
Owners manual under MISCELLANEOUS PARTS/ACCESSORIES
Gerry
denis2
Hi Gerry thanks for trying to help . But I am still lost wether the filter pullss of or screws off But looking at one of the exploded views of the filter asseembly there looks like a thred at the top ,so it must screw off Thanks Denis
moi
It doesn't unscrew Denis. It's a "ball & socket" type fixture and it has to be pried off. Needle nose pliers wedged between the two parts worked for me.
denis2
Thanks again Gerry I managed to open it today, I took the risk and unscrewed it off. Must be a different model to what you thought Cheers Denis
