FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
'86 Sundancer 260 Mercruiser
Engine has been torn apart a bit already, I'm wonder what the small rubber hose coming from the water pump connects to...heater?
Also the clear tube it starts at the fuel pump and goes to... guessing the fuel tank?
That one goes to either the carb or flame arrestor (depends on the carb) it's to dump fuel from a fuel pump failure into the carb so it doesn't go into the bilge.
The small hose on the circ pump is probably for a cabin heater or a water heater. You would typically find the pressure side of that unit on the intake or thermostat housing.
