Jim Werner
Thread starter- Joined
- Aug 6, 2011
- 4
Hi to all! I'm in the process of working-beating on a 79 700 skier. I rebuilt the carbs,replaced the impeller and gasket, and the lower end seal and "O" ring. I had to replace the two plastic pieces on the distributer linkage because the were broken and wired together. I checked for spark then I mixed up some 50:1 and gave the motor a good priming. hit it with a little S.F. and ........and.........and........just alot of smoke but no ignition to speak of. I then replaced all the fuel lines, because I felt that this is a fuel issue at this time and checked the fuel pump diaphram for holes etc...checked the fuel filter, and rechecked the carb bowls for debris ..nothing found, and decided to give it a go....still nothing..Now comes the first hand full of my hair on to the shop floor. So now, did a compression check and this is what I found
n #1 160, on #2 160, and 115 on #3, got gas, got spark, got compression it should start, or run for a few seconds right, or am I sadly mistaken.
