Re: what wood to use for a casting deck
1/2 inch might be too flexy if there isn't anything underneath to support it, but as long as you have some sort of support underneath, 1/2 inch would be optimal. You want to watch the weight issue, too thick and you are just lugging around extra weight, which wastes gas and makes the boat slower. I have had succes with ACX, just paint it with a couple coats of 1 part polyurethane paint, $20-ish bucks at the hardware store, its used for decks and garage floors and anything that sees exterior exposure. Then you used some decent marine carpet, glue it on so you don't have the chance of staples wicking moisture into the wood, and it will last as long as you want it to. <br /><br />Now that the better half and I have been using Skanky Beast, she has requested that I come up with a sort of insert that fits into the bow seating area that would make the entire front flat for laying purposes, which is fine with me because that also would create a casting deck, so that will happen when the boat comes back out of the water....
