Re: what use for stringers and foam
I used polystyrene builder's foam I got at Lowe's in my 16' bass boat when I replaced the floor. I got 4x8' sheet 2" thick for ~$20, which is equal to around 5 cubic feet, but it has to be cut to fit. Circular saw works great, but don't run at full RMP's or else the blade will get hot and melt the foam. I just tapped the trigger occassional and it cuts like butter. I glued it to the floor with foam board glue (PL brand).
I used a compass to trace the contour of the floor along the edge of the foam, cut the angle of the floor along the traced edge (used an angle finder for that - turned out to be ~15 degrees), and figured out where ther floor would be to cut it for height using a straight edge (level) and tape measure to the hull.
