What trim gauge do I buy?
crazy_cowboy_01
Hi guys. I have a 1974 evinrude 70 hp with trim and tilt. I have the sending unit but I do not have a trim gauge for it. I think the gauge number I need is 174083, which replaces 172922. But I can find any gauges with these item numbers new or used. Does anyone know if there is another number gauge that will work with my motor? Do I need to know how much travel my trim has and use that info to find a gauge? Any help would be appreciated. Thanks.
emdsapmgr
The factory parts diagram shows part number 172658 for the trim gauge. Bombardier has a new one of these in their "vintage" warehouse. Contact an Evinrude dealer to purchase one.
kjdunne
Aftermarket gauges are available from Teleflex and others. Just be sure to get one designed for Evinrude / Johnson outboards.
crazy_cowboy_01
Ok thanks. I purchased to nos one from bombardier. Do you know if there was a factory tachometer available for my Motor and what the oem number for the guage is? I have a grey wire on my remote control and the book says that wire is a tach hook up.
emdsapmgr
You can look up your gauges yourself. Check out the original factory parts lists at this website: epc.brp.com. When you get in there, don't look in your year's engine for the gauges. They are considered an "accessory", so look for that section instead- and your year-you should find appropriate part numbers.
