What tread does 06 etec 250 use on flywheel for lifting?
speed_demon
On this motor you install a lifting plate with three bolts on the flywheel. Same holes used to remove flywheel. We have fabricated a plate but don't know what thread the flywheel uses. I tried 8mmx1.25 and 8mmx1.00 but neither wanted to tread smoothly. When the dealer loaded the engine their bolts slipped right in. When I called they said 8mmx1.00.
Anybody know the correct thread? Thanks!
speed_demon
Re: What tread does 06 etec 250 use on flywheel for lifting?
I've seen a couple people use 5/16"-24 (fine) but I was told everything is metric.
boobie
Call BRP customer service and ask them.
speed_demon
Thanks. They transferred me to Evinrude and answered my question. 5/16-24 and 1 3/4" long with factory lifting eye.
boobie
If you're using your home built ring, make sure you use Grade 8 bolts.
