What to use to "glue" transducer to hull
Rupp
Guys,
My 2000 Larsons transducer finally gave up so I found a replacement and have removed the old one. Now what do I use to affix it to the hull. I've read slow cure epoxy but I see many people using JB Weld 5 minute hold 1 hour cure. What's the correct epoxy to use? Thanks in advance.
Slooooooowwwwwwwwwwww cure epoxy
You need the bubbles to come out
Rupp
Do you have a suggestion on which slow cure to use?
Mc Tool
I used silicon ,wedge shaped slab , put edge of transducer on thick side of silicon wedge and sorta roll it on so as to push out 90% of silicon (yeah , bit of waste ) and any bubbles . Then you can "cheese wire " it off later if needed.
Chris1956
Honorary Supreme Mariner
Gee, if you can put it flat on the hull all it needs is to be wet.
On my SeaRay, I needed to toss a cup of water into the bilge when first launched in the spring. The transducer stayed wet all season long
