What To Look For When Outdrive Stopped Working
patrickwebb
im buying a 1985 chris craft scorpion 168 with a 140 in it, the guy said the out drive is shot, he said he was driving and heard a noise, before he could slow down the noise got louder and the outdrive stopped working.
its a three hour trip to go get the boat, but its also a really a good price
any help on what to look for or what to expect would be greatly appreciated.
Bt Doctur
Re: What To Look For When Outdrive Stopped Working
Well, take the vent screw out and check for oil level, loosen the drain on the bottom and let a few drops out.
If he`ll let you, pull the drive for inspection.
Depending, you can get a SEI for $1200 or so.
Ayuh,....
Just Plan on replacing the Outdrive,.....
That way the Only Surprise might be that what's there is salvageable......
patrickwebb
168 means its 16' 8 inches correct?
crazy charlie
[QUOTE
any help on what to look for or what to expect [/QUOTE]
Expect to buy a new outdrive
patrickwebb
ok so i got the boat, the only think wrong with it was the gimbel bearing!!
o mayne thats so sweet!!
does anybody know what the fuel capacity is on this boat or how i could find out?
JustJason
uhmm... you could run it dry then see how many gallons it takes to fill up.
wvwarlock
if you have the in deck tank, take the cover off and there will be an id tag that will give you the specs and it should be near the fuel gauge sending unit. thats how i found out my capacity.
good luck
