bozza_boatie
- Apr 13, 2003
- 65
My 4hp Johnson seahorse which i believe is a mid 80's model seized about a year ago. I decieded to pull apart the motor and try fix it. <br /><br />With a little help from Clymer repair manual( I stress a little because it didnt have anything helpful) I pulled apart the engine right down to the cylinder which had rusted causing it to stop moving hence seize. So a hit it out with a hammer and now it is moving. <br /><br />Now i have to put the engine back togeather. I have some Questions though.<br /> <br />1. Do i have to put any product or lubricant inside the head to make the cylinder move easier?<br /><br />2. Do i have to replace any parts (other then the gaskets) as they all seem to be in good working order?<br /><br />3. Can I use only 1 piston ring on one of the cylinders.<br /><br />4. How do I know if the engine has good compression.<br /><br />Any other advice that i may find helpful in my rebuilt please tell me?<br /><br />Bozza
