drewmitch44
- Jun 26, 2005
- 1,749
Im ready to put the transom wood in and im useing PL poly for the bedding on the bottom and for the bond to the outer skin. I need to know if i need to glass the back of the wood that is going to touch the outer skin of the transom even though im using the PL Polyurethane for the bond between the wood and the outer skin of the transom? Im useing the Polyurethane for bedding to the hull and to bond it to the outer skin of the transom. After it cures im going to use roving to seal up the top and inside and also to the sides of the hull. Can i do this after the wood is bonded to the outer skin?? I have already bonded the transom together if you didnt know that. I kinda would like an answer soon as im doing this now! Here is some pics.
Thanks!!!!!!!!!!!!!!!!!!!!!!!!
