What steering system do I need?
Toallhisdoom
1987 skeeter starfire 175-D with a GT 150 johnson.
Cables siezed up. Teeth in helm stripped.
So I need a whole new setup.
It currently had a dual cable rotary helm setup on it. Do I need a dual helm for a 150? It only does maybe 47mph max.
I really know nothing about these systems so if there is a better setup, or cheaper, or if I only need a single cable setup that would be great info! Anything helps! Thanks!
if you have two helms, yes, you need a dual helm steering
if you have a single helm, then you need a single helm system
I looked up your boat, you have a single helm (only one steering wheel). you do have dual consoles
not sure what you posted, however iBoats sells steering
http://www.iboats.com/Boat-Parts-Acc...steering&s=sol
the two things you need to know, are you currently rack and pinion or rotary helm and how long is the cable. your current cable has a length printed on it.
then I suggest you buy the no-feed-back (NFB) version.
here are rotary http://www.iboats.com/SeaStar-Xtreme...view_id.961870
here are rack and pinion http://www.iboats.com/SeaStar-Soluti...-view_id.40295
Toallhisdoom
It is rotory bUT it is a dual cable system.
then spend the extra $200 on the dual cable version.
I would buy from iboats. Its up to you if you want a single cable or a dual cable
