What size prop do I need?
Geardog71
20140406_124314_resize_20140505_232521.jpg 50 hp ELPTO 2 stroke. Serial number tag says 5500 max rpms. When the boat is loaded with 2 or more tachs. out full throttle at 5500. When I'm fishing alone tachs out at 6200. I would like to get more top end speed while still maintaining no more rpms than called for. Not looking to blow up motor Would rather buy a new prop.
jestor68
Re: What size prop do I need?
You want to prop your motor for the "typical" load you normally carry.
Obviously, it's now propped for the take along a couple of buddies load with the 14 pitch prop.
By yourself, you could likely run a 17 pitch prop(the biggest I see available) and be at about 5600 rpm, with lots more speed.
But that prop probably wouldn't work well with the buddy load, since you seem to dropping about 700 rpm with them along; which might cause you to drop to around 4900 rpm then.
With the range of 4500-5500 rpm, you should still be within the range, but it wouldn't perform as well with the buddy load.
So, you might end up with 2 props(like a lot of us); the higher pitch for lighter loads and the present 14 pitch for when you take the gang along. It only takes a minute to switch out props for the day's requirement.
The motor's hp is rated at 5000 rpm.
Speed readings to go along with the rpm readings are needed to figure slip percentages.
By yourself, with a 17 pitch prop at 5600 rpm, you should see 40ish mph speed.
By the by, the Mercury prop selector indicates that a Tracker type 16ft aluminum bass boat with a
" light " operating weight of about 1285 lbs should turn a 15 pitch Spitfire 4 blade prop at around 5300 rpm @ about 35-36 mph.
This might be a indicator that your tachometer is off. Perhaps you should have the tach checked before doing anything.
Sea Rider
It's all related to "taking the gang o not taking it" usually have my rib rigged to have max wot rpm factory stated for my engine with me alone, if adding 2 mates max rpm will drop to middle min-max safe parameters. If adding one more wot rpm will drop to min rpm which don't like at all.
So for my peace of mind only driver + 2 max extra boaters are allowed as I enjoy plane boating rather than fast displacement/non planing boating. This doesn't mean that can't carry more, will need to be at any throttle position except wot or could be lugging my engine severely with my standard factory delivered prop.
In your particular case could install a prop that gives full 5500 wot rpm with you alone and lightly loaded boat, as soon you start to add extra boaters rpm will drop accordingly probably to middle wot safe rpm for that engine. Will need to test different loads with tach under trial.
Happy Boating
Geardog71
Thanks guys I will take your advice. Went to my local Bass Pro Shop yesterday and went straight back to the service department. Stood there and told the tech exactly what I have told you. All he could say was, the factory put on the prop that is meant for that boat. If you are running 6200 rpm you need to trim it down, you have it trimmed too high. I was thinking to myself duh, like I didn't know that already. I trim my motor all the way up until the sound pitch changes and then I bump it back down a couple of times until the pitch lowers again. Some help he was!
steelespike
You will get better results if you start your own topic. Use the tab at the top of the prop page.
We will need to know if there is any gear reduction.Also may need the details on the Wellcraft 3200.
The experts here may be able to give you a starting point. You may be able to find a dealer that will let try some props
with the understanding your buying them there.Usually requires a deposit.
