Re: What size bilge pump??
i personally run to independent bilge pumps, one with the 3 wire, that has and automatic float switch, and manual switch. on one battery and thru hull fitting. i also run a manually switched on another battery, and separate thru hull fitting. i learned the hard way by having a pump go out. while in the Fl keys last year, over a foot of water in the boat from an afternoon storm.
