Yesterday I decided to work on my newly purchased 1971 Glassmaster boat (That has not been in the water yet). After thorough inspection, I discovered the plywood floors were waterlogged and rotten so I removed them. Now that the hull is exposed, I want to coat it with something as a precautionary measure before putting the flooring back in. I don't see any holes or cracks in the exterior, but I would hate to do all that work to find out the boat is leaking and have to tear it all back out. So here are my questions:
1. What should I coat the hull with?
2. Should I coat the underside of the subfloor? If so, with what?
3. Once the (2) layers of plywood flooring are reinstalled, what should I use to coat the inside of the boat & top of new flooring?
Thanks
Thanks
