What prop should I use? What comes stock?
Havasu bound
I have 5.7GXI-F. It has a 14.25 x 17. It has a good hole shot and tops a approx 4000 rpm. I spun the hub and when asking around I was told I should be running from 4400 to 4900 rpm. Suggested going to 15 x 15. Does this sound right? Prop pushing a 26' tritoon. Dont know the gear ratio. Any thoughts or suggestions?
90stingray
Re: What prop should I use? What comes stock?
Are all these props just aluminum 3 blade? The 17 sounds about right for stock. You could drop to the 15 and see how she does. Try to find a marina or somewhere where you can return it if its not quite right. That way you will get what you need and only have to buy one prop.
SparkieBoat
most pontoons I see have either 15 or 13 pitch props. you may consider a 4 blade 13 pitch..should get you into the mid 4K rpms.
