etracer68
Ensign
- Oct 11, 2009
- 906
Re: What prop do I need?
I cant see, but you may have ok with just the trim rod assemibly. On the front of the motor there should be something that would push against the trim rod. I cant see from the pics of your unit. On my Johnny, its part of the steering bracket. when you lower the tilt, it fits against the rod (C shaped). If you have a rod that with fit through the holes, slowly lower the motor, and look where the area on the motor will touch the rod. You need the trim rod, and choose the hole where the boat gets on plane fast. To far back and it will not get on plane fast, and bounce the bow, to far forword, and it will plane fast, but drive the bow into the water, and not handle well.
I just looked at the parts list again, its the bracket swivel, has the C shaped area. You should be good to go once you get your trim rod.
